@Gabor2 can I reach you directly for some clarity on the capacitor? My email is kkmukiri@gmail.com.
I have two values for the same capacitor. one that's 16V and another 200V. Would like to share the picture of the circuit for your advice. Thanks
Thanks Shizo. The information of the board is not that clear. From the front part of the board where the capacitor is, its EB801 while at the back what comes close is CB809. As I has mentioned, the current capacitor readings are Asahi RH 105 1086JPET. Unfortunately I cant find such a capacitor online.
Hi!
I hold in my hands EB801 not Asahi it's SamXon 22µF 160V it's for 32" chinese tv: "Fox 32DLE192" led backlight is: 2stripes with 6led 6V (2x6x6V=72V) if your display is different size then I will searched it from my box..
Hi!
Maybe similar:
UMC TP.MS3463S.PB801 MAIN SCH Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com)
10uF-0805-X5R-+15%-16V
The values visible on the capacitor are Aishi RH105 1806JPET.
Hi
Its not good info near USB !!, search in PCB capacitor number like Cxxx.
Hi!
