Yamaha RX-A1050 - Main Power Supply board schematics
Hello,
I'm looking for my Yamaha RX-A1050, the electrical schematic of the main power supply board.
I found 2 SMD 1w resistors KO (burner) and I can't read the corresponding values. These resistor are : R3502 & R3503.
Thanks in advance for your support.
Regards
hifista
hifista picture
Hi!
The resistors value is 0,12 Ohm / 1 W, but I think these resistors burned out because Q3501 was also shorted.
You can find the service manual here:
https://elektrotanya.com/yamaha_rx-a1050_rx-v1079.pdf/download.html
Hifista.
SzBálint
SzBálint picture
