Samsung TV GU55AU7179uxzg Does not Switch on suddenly
3 posts / 0 new
donottmar
donottmar picture
Hello everyone,
i am new to the forum and i would like to save a TV from the dumpster. I figured out that IC207 is broken on the mainboard of this TV. Does anyone have a schematic for these kind of TVs or even have the same and knows what IC this is? I presume it is a voltage regulator. The TV is totally fine but does not turn on any more. The power supply is perfectly fine. I desoldered this IC as it was getting very hot and was the only issue i found.
Thank you!!!
Choose the appropriate forum, then give it a title and enter your question.
The topic title contains the brand and type of the faulty device. It also briefly describes the problem.
e.g.: ACER AL1711 monitor screen turns off after 5 seconds
The incorrectly named topic will be suspended and then deleted after 48 hours! While suspended, others will not be able to comment until you correct the title!
The incorrect title can be corrected later (within 48 hours) by clicking on the "Edit" tab.
Request a drawing, service manual, via the "CLICK HERE" button in the "Search/WANTED" box on the right!
DO NOT ask for a car radio code in the forum!
If you are not familiar with electronics, DO NOT attempt the repair!!
You may even suffer a fatal electric shock! Contact a specialist!
Have you read it? - kalex moderator
--> I corrected it. Thanks for pointing out!
Shizo
Shizo picture
Hi
What is mainboard BN number ?
donottmar
donottmar picture
Hi,
The board says:
TH10
BN9653076A
AM5RR275400
R.A
The power board says: 3IN1 Kant Su2e 50/55 inch
Is that some info which can help?
