Hello guys,
I have a LG TV OLED55C9PLA which does not start at all.
The only sign that is alive is some vertical colored lines on the right side of the screen that are appeared at the beginning and that's it. After that black screen.
I have uploaded a short video (more than 3Mb) to understand better what I mean.
https://www.dropbox.com/scl/fi/k41dudzh2jk44mcl98n3c/20241117_200414.mp4...
If you have any experience from such problem please help me to fix it.
Thanks in advance.
Theo
Hello!
Its maybe unbeliveable but display is problem, this is LG's disease. Never buy LG OLED (It's produced in Egypt)
Hello Theo!
This problem is the display defect. Vertical line controller is bad. This defect can not repair, need change to new one display.
Laszlo
Hi Laszlo,
Thanks for your answer
You don't think that it is a matter of a Τ-CON ?
Sorry, but chengeing T-CON modul not possibile, because the T-con modul paring to OLED diplay in the factory. OLED display change is complete T_CON modul only.
Hi Laszlo,
T-Con board is a separate module
See this for example which is the same model.
https://www.rservis.com/cs/nahradni-dily/17335-lg-oled55c9pla-t-con.html
Dear Theo!
For 15 years, I was a service engineer at Philis' central service in Hungary. I also repaired LG devices in parallel. Every year I attended a service course for both Philis and LG devices. All OLED TV displays are configured at the factory for the T-CON panel. The white balance is set individually for all the LEDs of the display. Even if you find a disassembled T-CON panel on the Internet, it will not be suitable for your display. But you can try, but it won't be good. The reason why the vertical stripes appear on the display is that the matrix circuit is integrated on the LVDS connector cable of the display.
Laszlo
