I im repairing a hisense power board (RSAG7.820.5687/ROH). You have the schematic on your site,The problem is i can download it, open it but what it shows is component numbers and ínot values. Theres 3 resistors that have no numbers display (BLOWN). Resistor numbers are R904, R965, R966. I would be very greatful if this could be corrected the schematic or finding the correct values...
The problem was caused by a shorted back light led to ground, Which has now been corrected.
Thanks in advance...
I im repairing a hisense power board (RSAG7.820.5687/ROH). You have the schematic on your site,The schematic shows is component numbers only but not they values(resistance). Theres 3 resistors that have no numbers display (BLOWN). Resistor numbers are R904, R965, R966. Does anyone have the correct schematic or could find the correct values...
Ive learnt that R904 is a 10k
