Dear Sir,
i bought one old philips turntable .When I plugged in the mains transformer got burnt as the main condenser was short.I wanted the details of mains transformer as to what are the output voltages going to both the R n L channels.The techie requires tge details of thd inside windings .The numbers of the valves, philips minivatt of pre smp and output valves are wiped out.The manual available are not in english .
Thanks and Regards
Umesh C U
Hi,
Maybe these helps: https://elektrotanya.com/philips_ag1015_series_changing_turntable_chassi...
Otherwise you can find such videos on YT, and write us the exact type Nr too...
