hello
One device was Sony model 75x8500c with 6 blinks.
I changed the backlight. It was fixed. But after an hour it turns off again and flashes 6 times and I have to turn it on again. I tested the backlight and it was fine.
There is no problem with the connections. You had the same problem.
Thank you for your help.
Hi
Modify backlight current resistor to 50%
