HOLA ALGUEN PUEDE DARME INFORMACION SOBRE LOS PARLANTES QUE USA LA RADIO PHILIPS MODELO BX12A/19 O LA B6X12A/19 QUE NO LOS TIENE Y NO SE SU INPEDANCIA DE ANTEMANO MUCHA GRACIAS
Hello,
2 x AD 3800
High impedance loudspeakers ,800 (!!) Ohm.
Low impedance speaker can be matched by replacing the output transformers.
As Mr.SzBalint wrote,the schematic and data can be downloaded from here
Hello,
2 x AD 3800
Helló: csak ez van
https://www.radiomuseum.org/r/philips_b6x12a_19.html
