Hi and tnq you all for your time
I have a HP P2035 which its power supply is not working.
After many test it turns our that swiching mosfet K4005 is burnt, also 4 smd resistors are gone open.
The gate drive transistor Q502 with code H.Q is damaged too.
Now i need the exact value of two resistors, R503 which is for gate-source and R508 which is to bias transistor Q502.
(mentioned resistors are wiped out info and i am interested to go firt for real values before checking needed value by a potentiometer).
Following parts are not availabe to me and im seeking for a replacement of them by a good ones:
2SK3534 -> K4005
BC817 (sot-23) -> H.Q (sot-323) maybe its real code is 2SC4155A
Tnx in advance!
Following is an image of the board (don't think about missed parst as soldered out for cleaning or somthing else)
hello. talán benne van
https://elektrotanya.com/hp_laserjet_p2035_p2055_sm.pdf/download.html
TanQ for your help
But i just need a high res image of the back-side of the board.
If R503 and R508 smd resistors being visible to read their values which is written on their elemet then it will help me so much!
Tnx in advance
Does anyone have one of p2035 or p2055 hp printer series to take an image of its backside of the power supply board?
