Hello
my printer have a problem with the power supply and only measure 6V instead of 24V.
My printer is a Brother DCP-L2530DW
It won't switch on
I've already checked most of the components on the power supply
No short circuit
Fuses - ok
PTC/NTC - ok
Thermal fuse - ok
MOSFET - ok
Optocoupler - ok
Electrolytic capacitors - ok
C10 and c11 - ok (100pF and 470pf / 1000V)
Primär - OK - 320V DC -OK
Unfortunately I don't have a datasheet of the IC MIP0050 and can't make any measurements - ramp voltage, supply voltage etc.
I would be very grateful for tips
Hello:
talán benne van a tápegység rajza is
https://elektrotanya.com/showresult?what=Brother%20DCP-L2530&kategoria=&...
thanks i have already seen and read through it but there are no technical details such as wiring diagrams etc.
