How install bluetooth on krc 366 in place of cassette player Add new comment Comments 2025, May 24 - 12:17 #568534 Jaca 16 years 10 months***** Hi! From CD-CH input: https://www.pakwheels.com/forums/t/diy-kenwood-headunit-aux-adaptor/12471/2 In pin 3 there is a permanent 12V, may be you need an 5V voltage regulator, or Use +5V from the tuner pin 23 (C306 10uF), it switched on, when radio turned on.. 0
Hi!
From CD-CH input:
