Dear if that is problem happen for any of you please send me an email ,
I had got problem in this model of tv and board, the problem is there is no back LIGHT I cange one line of LED strip and when I work on with 2 line only the back LIGHT is go on but when I connect the 4 line of back LIGHT the back light is turn on for 2 seconds and turn of .
Thanks for help
Hi!
If one of led dead in a backlight the best way to change all of strip. Be careful, the individual LEDs forward voltage, 3 or 6 Volts.
Sometimes the LED turn on, but a bit heat, then turn off.
