Hi. I could not find the Power Board f101 fuse resistance value in the sony sdm hx 73 93 technical schematic. Can you help me with this?
Link:
https://elektrotanya.com/sony_sdm-hx73_sdm-hx93.pdf/download.html#dl
Link:
Hi!
Power board model number is IP-51125LB and board part number is 6871TPT251B.
Hello sir. not the part number, what is the fuse f101 material value.(for example 230v 10A 100 Ohm)
Is this the power supply?
Yes. T3.15AH 250V
(3.15A 250V.) Is this the value?
