I, i have a Toshiba Sattelite C50-A-19T (PT10F), Having these 4 qual components to generate 3.3v and 5v its part of a pwm driver but i dont known how to find the datasheet, the marking is ALW 3KAB.
I take out of board and measure with a multimeter they are N Channel MOSFETs, near the coil as part of High Drive and Low Drive PWM Driver.
What is the part number?
Can't find on Service Manual and BoardView
It have 4 pads 3 on bottom 1 on top!
Maybe like RV7*** ?
It is aproximatly 2mmx2mm package
B
What i need dfn2020-4.
alw ha megtalálod
vagy siaxxx sia432dj
Ok, i measure once again and it fit on dimession.
As source, drain and gate match as well.
Tankyou Very Mutch ::))
It's what i was looking for!
2 meg egy https://www.vishay.com/docs/63644/partmark_ppak_sc70.pdf
