nokia 7210 supernova phone, screen goes dark
Hello,
After I turn on the phone, the screen goes dark. As soon as I press a key, the screen lights up briefly and then goes dark again until I press a new key. The battery is new, charges well and holds up well.
How could I solve the problem?
The problem appeared suddenly, until then everything had been ok.
Thank you and best regards,
Vasile GRIGORE
Romania
TonyStark
TonyStark picture
Hello!
The error could be caused by water ingress, check the pcb, at the display connector. But it could also be a display error.
Tony
