Sony ICF-SW77 sound issue
Beim Synchrondetektorempfang geht der Ton weg.
Christoph Ellger
Christoph Ellger picture
Zeitweise kommt der Ton nach 2 Minuten.
TonyStark
TonyStark picture
Hello!
Thank you for the detailed and correct error description. Please review the attached service manual, take measurements, measure the SMD electrolytic capacitors, and check the pcb for soldering errors.
Your welcome!
Tony
TonyStark
TonyStark picture
