The SONY NX-50 with E:62:10 error indicates a lens stabilization or focus mechanism fault, possibly caused by physical impact, wear and tear, or a stuck lens. You can try to fix it by removing and reinserting the battery, gently holding the lens while powering on to dislodge it, removing and cleaning the lens contacts, or by resetting the camera to its factory settings. If these steps don't work, professional servicing or contacting Sony support is necessary.
Hi!
Generated by Google
Read it: https://www.videoonerepair.com/e6210-lens-error-hxr-nx5u-hdr-ax2000/
