Heloo to everyone!
i have an LG-37LH4000 and image freez for a few moment (4..5 seconds) then work fine for 1 or 2 seconds.The main problem that cause this could be the LCD panel or LVDS (T-CON).Where i can find schematic for LVDS (T-CON).The chassi is LD91G.
:help:
Thank you for your support.
2011, January 19 - 19:25
#1
schematic for Tcon? I think it is an impossible mission :) I never found tcon sch :(
In fact, the most of LCD TV has a lot of lcd panel... Every time another LCD..
You can buy good tcon from broken TV.. This is the only cheap way...
Hi!
Di you checkd these one pls?:
http://elektrotanya.com/lg_37lh4000.pdf/download.html
Kari
