Hello, I am in a repair KENWOOD KRF-X9995D.
Let me know if anyone is aware of how to reset the processor.
That is about a year ago I had the same problem with another amp of the same model!
So this is the second unit can not repair!
The main flaw is that the accumulation of around 1F 5.5V had spilled acid. was also in the same thing happened! ie it shows mute, but going into test mode, (having pressed the key "INPUT SELECTOR DOWN" and "POWER", the analog input works (but only in TEST).
Any help?
Thank you
      2009, May 9 - 01:45
    #1
Én most csak ennyit tudok segíteni..
http://www.webforditas.hu/
delon1
