2N30809 Dual FET ?
4 posts / 0 new
Technotronic
Technotronic picture
Trying to get a Leader 100mhz scope back in action, the Y axis drifts and this post seems to say a dual FET could be a cause:
https://www.electro-tech-online.com/threads/2n30809-dual-fet.104271/?hig...
The number seems wrong, and could it be a 2N3809? Schematic seems to indicate Q23A/Q23B is that part number.
I have uploaded the SM for the LBO-518 scope to the manuals section.
Someone on a ham radio forum said they have a LBO-516 plus a parts unit and
turns out it uses the same kind of dual FET. In that drawing its a ITS3809 as per the
parts list of the SM. SM for this is also in the manuals section as well.
More searching says there is a mil spec type part under 1853-0269 that may be the same.
Can anyone confirm what the part number is to use or a sub part that would work
KundK
KundK picture
Vote up!
You voted ‘up’
zsugori
zsugori picture
File csatolás:
Vote up!
You voted ‘up’
Technotronic
Thank you for the help. I got the AD3956 - 2 pcs. Turns out a 2N3956 is the same design. I will post results here once I install !
Vote up!
You voted ‘up’
