Hello Francisco,
Which type? /61,62,2464?
Schema 2464 (sorry,bad quality)
There is rarely a separate filament heating circuit,check the tubes,connectors,(broken ?) wires.
In the linked circuit diagram, there are a couple of filter capacitors in the ECC85 FM mixer heating circuit,their shorting can cause an error like this.Anyway,devices of this age (more then 60 yrs), it's recommended to replace the paper capacitors.
Good luck to repair.
tj The community of Elektrotanya appreciates if you communicate in English, not Spanish, with a mixture of German.
Hello, I already solved it, the contacts of the 4A fuses were sulfated, that's why it failed; thank you.
Hello Francisco,![smiley smiley](//cdn.ckeditor.com/4.14.0/full-all/plugins/smiley/images/regular_smile.png)
tj
I already managed to solve the problem, the contacts of the 4A fuses were leaking; thank you.
Hello
I don't know what you say, please write in english.
apróság, de nekem már sokszor segített
https://www.deepl.com/translator
üdv attila.p
