Akai AA-V12DPL, no sound
There is no sound on all the channels,is this a common fault I found this amp in the dump...only the rear speaker channels worked there is also no power to the auxiliary power points I checked for dry joints on the circuit and repaired those I found still no luck...
Can you advise....if just downloaded the service manual
