It it has power, and the pump makes noises, but does not run, it can be just a simple object inside the pump (hair-slide, money, etc) and the pump can't turn from that... Just simple remove the object..
Plan B., Is a bit more expensive... It can be, that the shaft of the pump is worn out, or the magnet is broken. In this case, You have to replace the pump..
Hi,
