Baxi eco 240 Fi boiler not working properly
Buna ziua,am o centrala Baxi eco 240Fi cu urmatoarele probleme 1) centrala este pe pozitia iarna si cand termostatul decupleaza incalzirea calorifere si vreau sa dau drumul la apa calda centrala porneste aleatoriu cateodata da cateodata nu 2) in momentul cand termostatul comanda pornirea centralei la inceputul functionarii apar intreruperi la aprinderea flacarii adica ledul martor aprindere gaz se tot aprinde si stinge de cateva ori pana functioneaza continuu.Multumesc anticipat daca puteti sa ma ajutati.
vasile patcas
vasile patcas picture
Hello, I have a Baxi eco 240Fi central heating system with the following problems 1) the central heating system is on the winter position and when the thermostat disconnects the heating of the radiators and I want to turn on the hot water the central heating system starts randomly sometimes yes sometimes no 2) when the thermostat commands the central heating system to start at the beginning of operation there are interruptions in the ignition of the flame i.e. the gas ignition indicator light keeps on and off several times until it works continuously.Thank you in advance if you can help me.
Shizo
Shizo picture
Hello!
It's maybe capacitor problem, check main electrolitic capacitor (location: near transformer and trimmer potentiometer).
Shizo
Shizo picture
Hello!
Elektrotanya members 90% don't speak romanian, please write in English..
