Hi,
I am new to the forum, although you guys helped me a lot in the past with schematics.
I have a DigiPro 1000 S Board with failed diodes (D8 + D9, p.6 digipro_1000_sch_pcb.pdf) on the output. The diodes failed short and created an arc between the high voltage outputs of the amplifier. That burned up the board pretty badly. The capacitors C25 + R43 (10k) and C26 + R25 on the top side got also destroyed. Can someone tell me what capacitor C25 was? In the available schematic, the type and value is sadly not noted.
https://elektrotanya.com/digipro_1000_sch_pcb.pdf/download.html
The driver that was attached survived the ordeal.
Best
