Grundig Music Boy 70 - loss of audio
Hi, I have a Grundig Music Boy 70 portable radio with very faint audio output.
The speaker, 3.2 ohms, works fine, the volume control works fine. Replaced various suspect electrolytic capacitors which didn't help.
On power up, the initial volume is louder but it quickly fades to almost zero, in less than a minute.
Been looking for schematic diagram without much luck.
There are two main ICs, a TA2132BPG (believe as pre-amp stage) and a LS820, 8pin, (probably audio amp) but, had little luck on data sheets for those, too..
Any tips on troubleshooting this problem?
I would like to save this radio from a destiny in the landfill.
Much appreciated,
Blade.
SzBálint
SzBálint picture
Blade
Blade picture
Thank you SzBalint,
This IC is working then, as I can tune every frequency/band... but, I'll check the power output on it, just in case.... Cheers.
SzBálint
SzBálint picture
tomirevesz
tomirevesz picture
Hi!
It may be similar to the 71 model, in which the radio IC is also TA2132, and the power amplifier is KA2201.
GRUNDIG MUSIC-BOY-71 SCH Service Manual download, schematics, eeprom, repair info for electronics experts
