Grundig SO 161 Ua blown fuses
Need to know what the correct fuses are for a Grundig SO 161 Ua console. Recently acquired this and all the fuses were blown. Also need to know a source for the correct fuses.
Thank you!
torokj
torokj picture
Hello Bill,
At 220 Volts, the fuse is 0.5 A (110V -1A).
If there is any fault (rectifier, electrolytic capacitor, faulty electron valve), the fuse blows.
The power supply must be measured in a disconnected state.
Also check and replace the grid coupling capacitors.
Good luck to repair.
tj
SzBálint
SzBálint picture
