Grundig GV200 to GV250 VCR Electronic Lock Cancel
Press the 'CODE' button on the remote control handset. Enter the numers 4 9 3 4 on the remote control handset in this order and confirm with the 'OK' button. Press the STOP button.
Grundig GV201-1 VCR Electronic Lock Cancel
Press the 'STANDBY' button on the remote control handset until 'FREE' is indicated on the display of the video recorder.
Grundig GV25SV/5 GV45SV/5 VCR Electronic Lock Cancel
Press the 'STAND-BY' button on the RC until 'FREE' appears on the display of the recorder.
Grundig GV280PC GV280S VCR Electronic Lock Cancel
Enter the numbers 4 9 3 4 on the remote control handset in this order and confirm with the button 'OK'. Press the STOP button.
Grundig GV400 GV400GB GV400OST VCR Electronic Lock Cancel
With the video recorder switched off (Stand-by) press the Stop button on the RC until 'UNLO' appears on the display of the recorder.
Grundig GV4000VPS GV4001 VCR Electronic Lock Cancel
Grundig GV4003VPS VCR Electronic Lock Cancel
With the video recorder switched off (Stand-by) press the Stop button on the RC until 'FREE' appears on the display of the recorder.
Grundig GV400VPS GV401VPT VCR Electronic Lock Cancel
Press the 'CODE' button on the remote control handset. Enter the numers 4 9 3 4 on the remote control handset in this order and confirm with the 'OK' button. Press the 'STAND-BY' button or disconnect the recorder from the mains.
Grundig GV4010SV-VPT GV4092.. GV4192VPS GV4200SV-VPT GV4400HiFi GV4592.. VCR Electronic Lock Cancel
Grundig GV402 VCR Electronic Lock Cancel
Grundig GV404SV GV405EURO GV406EURO VCR Electronic Lock Cancel Press the 'CODE' button on the remote control handset. Enter the numers 4 9 3 4 on the
Grundig GV410 VCR Electronic Lock Cancel
Grundig GV410VPS GV411 VCR Electronic Lock Cancel
Grundig GV411-1 VCR Electronic Lock Cancel
Press and hold the 'STAND-BY' button on the RC (ca. 5s), until 'UNLOCKED' appears on the display of the recorder.
Grundig GV411OST GV412 VCR Electronic Lock Cancel
Grundig GV414SV GV415EURO GV416EURO GV420VPT VCR Electronic Lock Cancel
Grundig GV430 GV430GB VCR Electronic Lock Cancel
Grundig GV430VPS GV434SV GV435EURO VCR Electronic Lock Cancel
Grundig GV440.. GV450.. GV460.. GV464.. GV465EURO GV470.. VCR Electronic Lock Cancel
Grundig GV500.. GV501VPT GV505EURO GV506EURO VCR Electronic Lock Cancel
Grundig GV5000 GV5000GB GV5000VPS GV5000VPS/5 VCR Electronic Lock Cancel
Grundig GV5002VPS GV5003 GV5008 GV5050 VCR Electronic Lock Cancel
Grundig GV5050SV GV5050SV/1 GV5055EURO GV5095.. VCR Electronic Lock Cancel
Grundig GV510SV GV511 GV515EURO GV530.. GV535EURO GV540.. GV545EURO GV560.. GV565EURO VCR Electronic Lock Cancel
Grundig GV5300.. VCR Electronic Lock Cancel
Grundig GV5395.. GV5400.. GV5695HiFi VCR Electronic Lock Cancel
Grundig GV600 GV630 GV640HiFi GV640NIC GV645EURO GV650HiFi GV660HiFi GV660NIC GV665EURO GV670SHiFi GV670SNIC GV690SHiFi GV690SNIC VCR Electronic Lock Cancel
Grundig GV6096SV GV6096SV/1 GV6396SV GV6596HiFi GV6596NIC VCR Electronic Lock Cancel
Grundig GV740.. GV745EURO VCR Electronic Lock Cancel
Grundig GV7400.. VCR Electronic Lock Cancel
Press and hold down the buttons 'STAND-BY' and 'SELECT' simultaneously on the RC until *** simbol disappears from the display of the recorder.
Grundig GV7497NIC VCR Electronic Lock Cancel
Grundig GV8.. KV8.. SE8.. VCR Electronic Lock Cancel
Grundig GVP600ICNEURO VCR Electronic Lock Cancel
Grundig KV5001VPS/5 KV5301VPS/5 VCR Electronic Lock Cancel
Grundig MV4005 MV4105 VCR Electronic Lock Cancel
Grundig SE4100VPS SE4104SV SE4120SV VCR Electronic Lock Cancel
Grundig SE5102SV SE5104SV SE5106HiFi VCR Electronic Lock Cancel
Grundig SE6102SV SE6104SV SE6106HiFi VCR Electronic Lock Cancel
Grundig SE7104SV VCR Electronic Lock Cancel
Grundig SE7105 VCR Electronic Lock Cancel
Grundig SE7106HiFi VCR Electronic Lock Cancel
Grundig TVR3700 VCR Electronic Lock Cancel
Press and hold STOP button on the RC and depress the PLAY button on the video recorder. Press the 'STAND-BY' button or disconnect the video recorder from the mains.
Grundig TVR3701 TVR3705 TVR3710 TVR3720 TVR3730 VCR Electronic Lock Cancel
Press the cursor buttons on the RC in this order: VOL+, VOL-, PR+, PR-.
Grundig TVR4500 TVR4510 VCR Electronic Lock Cancel
Interconnect the service test points on the ***board control unit for a short period. Switch the unit off and disconnect it from mains.
Grundig TVR5100 TVR5130 TVR5500 VCR Electronic Lock Cancel
Grundig TVR5510 VCR Electronic Lock Cancel
Grundig TVR5530 VCR Electronic Lock Cancel
Grundig VS200 to VS267 VCR Electronic Lock Cancel
Switch the video recorder off. Remove the top of the cabinet. Unplug the B1 connector on the sequence control. Switch the recorder on. After approx. 2 seconds, re-insert the B1 connector. Switch the video recorder off. Re-fit the top of the cabinet.
Grundig VS300 to VS460 VCR Electronic Lock Cancel
Switch the video recorder off. Remove the top of the cabinet. Switch the recorder on. Interconnect the service test points on the ***board control unit for a short period. Press the STOP button. Switch the video recorder
off. Re-fit the top of cabinet.
Grundig VS500 VCR Electronic Lock Cancel
Enter the numbers 4 9 3 4 on the remote control handset in this order and confirm with the button '0000'. Press the STOP button.
Grundig VS505 to VS510 VCR Electronic Lock Cancel
Grundig VS520 to VS550 VCR Electronic Lock Cancel
Grundig VS600 to VS960 VCR Electronic Lock Cancel
