Harman Kardon Festival 60 won't power up
I have this fantastic system which  will no longer power upcrying.  If I push the power button top right... it illuminates briefly   the unit shows INITIALYZING.... then  shuts down with a "click"  in 1-2 seconds  as if it has a power overload .. all back connections check ok    no shorts
 the unit worked fine for years  but suddenly this happens.. looks like some protection circuit is shutting it down. I looked at diagram !!!  but not enough details  or  circuit description on how it works .  Paid $400 at COSTCO years ago  and shop repairs
are prohibitive if I can find the problem .  thanks for any clues . If it goes in the junk pile  I'll have to whip out my pristine  SX737
SzBálint
SzBálint picture
üdv:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://audiocircuit.dk/downloads/harmankardon/HarmanKardon-Festival80-r...
hifista
hifista picture
Hi!
First, you should determine which unit is faulty.
The rear ribbon cable should be pulled out of the upper unit and the control unit itself should be turned on.
If the same error is experienced, then this control unit will be faulty.
Its repair requires an experienced specialist, because it is a very complicated device.
Hifista.
Crosbyman
Crosbyman picture
Thanks for comment ... I will try again but  I recall pulling the ribbon cable  and still the control unit failed as you indicated.
I have repaired radios and misc. electronics before but this animal seems  designed by NASA !   no wonder it was selling for $1K+  years ago sad
