HK audio Pulsar 112FA power supply issue
I have a HK Pulsar 112 FA. Suddenly the power supply got burnt. Then find out that the Swtching power IC was cracked out. Then i ordered the part and replaced it. But still it does not start. I have tested 15V+ and 15V - are there. Still the power LED does not lighting up. And also Power for the Amplifier is not right. Did not find the Schematic to follow. I am an experience Electronics technician for last 30 years. If some can give me some advice or the Schematic of the power supply would be greatly appreciated.
Also i have a HK 210 A sub woofer had the same problem and managed to do it. There i found after replacing the Power IC another NPN smd transister was deffective. Now it works, but it takes about 50 second to switch on after making a switching noise like tik, tik, tik tik and then comes the green led and works hours without any problem. Any ones ideas or help would be greatly appreciated.
Shizo
Shizo picture
Hi
I don't know HK models, but in similar must have 5V from 7805 or from DC/DC IC, search it and measure input  of +15V ? If not, maybe open circuit..
