Have you tried to connect an external monitor to the notebook?
Have you tried to check the cable inside the notebook between the motherboard and the display?
Thank you for answer,
I not use the external display
I bought this refurbished notebook last year, I'm not computer technician that's why i need help from anybody
Remove the lcd bezel, tilt out the raw panel and check its type
if not same this pn number not original.
490097-3D1
490097-3D2
490097-7D2
490097-2D2
490097-1D1
Row loss single cable type and between dual cable controlled raw panel with occurs.
This laptop is original assembly with single cable controls raw panel.
Solution, contact the laptop service center.
This is a hardware problem. You don't want to check the problem with an external display, you don't want to disassemble the notebook, so... I think... you should take the notebook to a laptop service center.
b.r
Hi Tyler,
490097-3D1
490097-3D2
490097-7D2
490097-2D2
490097-1D1
hnd,
Hi Specialist,
Any idea of the issues?
b.r
O.K. First connect an external monitor to the VGA or HDMI port and check the display on it.
