Kenwood KA-6004 capacitor C303 in unit is 100uF , in Schematic it is 1000uF
Error message
  • The comment you are replying to does not exist.
Kenwood KA-6004 Capacitor C303 in unit is 100uF, in the Schematic it is 1000uF.
I am ordering replacement capacitors for the Electrolytics, and at least one cracked 100Ohm resistor (re48 on Main Amp board), and I would like to think I am ordering parts to closely match the original. However, when I look at the label on C303 it says 100uF, and when I look at C303 on the schematic it says 1000uF.
Anyone able to confirm a working KA-6004 with a 100uF or 1000uF C303? This capacitor is between the positive (shown as 55V out) side and the negative side of the full-wave rectifier off the 45V transformer.
Thank you.
jens_hh
jens_hh picture
Hi,
1000 µF is no problem, it`s a smoothing capacitor, the higher the better. Only an exaggerated value say 10000 µF may destroy the rectifier due to the inrush current.
Regards Jens
Sam Duncan
Sam Duncan picture
Thank you for the input.
zsugori
zsugori picture
szerintem a trio-ban 100uf
a kenwood-ban meg 1000uf
Sam Duncan
Sam Duncan picture
Is the implication that I have a Trio Chassis, not a genuine Kenwood (I understand Kenwood was originally Trio-Kenwood: 1957:Kasuga Radio Company changes its name to Trio-Kenwood Corporation.) Why would the any equipment branded Trio not use the same schematics).
Either way, thank you for the input. I think I will, since I had 1000uF on the replacement parts list, to go with the 1000uF.
