My radio is erasing the numbers on the screen after 15 minutes of being turned on,
it works fine until the screen erases and transmits badly until the next day we return with the same behavior,
I want your help, thanks.
Check the following according to the Service Manual:
-Internal supply voltages
-SMD electrolytic capacitors
-Soldering quality, processor, eeprom LCD area mainly
-If there has not been a RESET on the device yet, try this and reprogram.
I hope I helped.
NEM, en a Tanyan levö cimre hivtam fel a figyelmet-ha man itt letezünk- s Te meg egy küsö linket adtal meg_az igaz, hogy ugyan arrol a temarol, de epp ez a lenyeg: ha megvan a Tanyan--minek adunk meg idegen cimeket-erted???
K.
Hello Pedregal!
I hope I helped.
Best Regards: Tony
http://www.radiomanual.info/schemi/KENW_VU/TH-D7A_E_serv.pdf
3
You voted ‘up’
Hi,
ET has a service manual too :-)
https://elektrotanya.com/kenwood_th-d7.pdf/download.html
rgds, Kari
You voted ‘up’
Köszi hogy belinkelted ugyanazt mint Én.
Ismétlés a tudás anyja
3
You voted ‘up’
K.
You voted ‘up’
Ertem.Koszonom a magyarazatot.
Legkozelebb megprobalok itteni linket adni.
Udv! Toni
3
You voted ‘up’
