Kenwood TS-430s intermittent transmission
Error message
  • The comment you are replying to does not exist.
My TS-430S  transmits 100 Watts on FM in any band in horizontal and vertical positions. Also, using the other modes (cw-am-ssb) has the same output in the vertical position but this output lowers and or finally becomes zero trying to turn the transceiver slowly (by two hands) from the vertical position to the horizontal one.
I think the above two cases have a difference in the IF unit which already has been resoldered in the past.
It doesn't seem to be a relay as the trancceiver operates normally in FM mode.
Please any ideas or suggestions.
Thank you
Kari
Kari picture
Hi,
I dont know how and what yuo do for output power measuring_plse check the specs from your rig: https://www.rigpix.com/kenwood/ts430s.htm
regards, Kari
TonyStark
TonyStark picture
Hello Panos !
See the service manual:
https://elektrotanya.com/kenwood_ts-430s.pdf/download.html
Good luck the repair.
Regards:Tony
