LG 22LH2000 TV unlock USB port
How to unlock the USB port on LG TV 22LH2000 for using a flash drive
spellfire
spellfire picture
Hello,
To unlock the USB port on the LG 22LH2000 TV for using a flash drive, you’ll need to perform a service menu modification, as this model originally has its USB port disabled for media playback. Here's a general guide based on community-shared instructions from ElektroTanya
⚠️ Important Notes:
  • This process involves accessing the service menu, which is intended for technicians. Proceed with caution.
  • Incorrect changes can affect your TV’s functionality. Only change the settings mentioned.
🔧 Steps to Unlock USB Port on LG 22LH2000:
  1. Access the Service Menu:
    • Use your LG remote and press the following sequence:
      MENU → MENU → 7 → 7 → ENTER
      (Some models may use OK instead of ENTER, or a different sequence like MENU → 0 → 0 → ENTER.)
  2. Navigate to the “Tool Option” Menu:
    • Once inside the service menu, look for Tool Option or Tool Option1.
  3. Modify USB Settings:
    • Find the setting labeled “USB” or “DivX”.
    • Change the value from 0 to 1 or 2 depending on the available options.
      • 1 usually enables basic USB functionality.
      • 2 may enable DivX playback support.
  4. Save and Exit:
    • Press Exit or Return to leave the service menu.
    • Power off the TV and restart it.
  5. Test the USB Port:
    • Format your USB flash drive to FAT32.
    • Load compatible media files (e.g., MP3, JPG, DivX AVI).
    • Plug it into the USB port and check if the TV detects it.
