LG flatron M2294D tv/monitor white picture
20 posts / 0 new
JIMMY20
JIMMY20 picture
hello to everyone!
i have this model LG. the problem is : i have sound on tv but white picture
this problem is everywhere tv,scart,hdmi and vga.i have checked all the voltage and its ok, i think maybe has got problem the ic100 (maybe has got resolder? i dont know) i want to help me if anyone has got an idea what is it or has the same problem and solved.
thank you very much for all.
JIMMY20
JIMMY20 picture
hello my friend kolya61!
i will checked but i believe the problem is on ic100
thank you very much!
JIMMY20
JIMMY20 picture
hi!
sorry for the late i apologise.well i have change the capacitors in mainboard
c:1141,1152,1163,1124,1138,1125,1140,1193 and the problem be continued
the chassis name/number of mainboard is: M19/20/2294D-PZ
LD84E
EAX43958708(0)
has anyone other idea what is?
thank you.
kolya61
kolya61 picture
Szia Jimmy !
Ez a hiba, ahogy Zoltán is írta főleg a mainboard feszültségek hiánya , vagy a biztositékuk szakadása után szokott lenni, a DC-DC átalakitókban.
Én főleg az 5 Voltot ellenőrizném a logikai panelen .
Üdv! Miki.
JIMMY20
JIMMY20 picture
hi!
Kari thank you for the translate!
thank you! :)
JIMMY20
JIMMY20 picture
hi zoltan35!
thank you for the info i will checked them!
thank you :)
JIMMY20
JIMMY20 picture
hi kolya61!
thanks, when i go in the office i will see the chassis name/number and i
tell you
thank you
kolya61
kolya61 picture
Szia Jimmy !
Üdv! Miki.
kolya61
kolya61 picture
Szia Jimmy !
Chassis name ?
Üdv! Miki.
JIMMY20
JIMMY20 picture
hi!
you have wright my friend and sorry i speak only greek and english (and my english is not very good),thanks for the translate
sincerelly jimmy.
city217
city217 picture
Szia.
Γεια σου. Μη διστάσετε να γράψετε στα ελληνικά, και τότε θα το λύσουμε. Αλλά αν γράφετε εσείς προσπαθείτε να μας εξηγήσει το πιο εύκολο και μπορείτε να μάθετε μια όμορφη γλώσσα. Καλή δουλειά.
kolya61
kolya61 picture
Sity !
Το αγρόκτημα βρίσκεται στην ουγγρική και αγγλική γλώσσα!
Jimmy αυτή την άποψη, γιατί έτσι δεν είναι;
A tanya nyelve angol és magyar.
Jimmy ezt tiszteletben tartja , te miért nem ?
city217
city217 picture
Szia.
Úgy van és pont ezt próbáltam megírni gyenge Görögömmel görögömmel. Ha ír Magyar magyarul akkor többen megértjük, ő pedig tanul egy szép nyelvet.
Kőbunkó: -csapkodva röhög-
Sity
[szerkesztve]
city217
city217 picture
Szia szerkesztve.
Ma borzalmas napkitörés volt, a héten eléri a földet. Úgy látszik engem már elért. :) Köszönöm a helyesííííí javítást, de jó lenne máshol is söpörnél. Csak viccelek! Tegnap ti söröztetek, ma én. Azért az nem semmi hogy még azt is leitatjátok aki nem iszik. A "kőbunkó" a Csonthülyében van. Nagyon jó film, te melyiket választottad volna? Nem a kollégára gondoltam, hanem a Sity-re. Habár ha ő Sity-zik, akkor én is kövezhetek.
Jóéjt, jó munkát.
Kari
Kari picture
Hali!
"Kőbunkó: -csapkodva röhög-"
Ja, bunkonak bunko vagy, csak eppen fabol_akarmennyit is okoskodsz...
Kari
[szerkesztve]
A stílus Uraim!!
sasa11
sasa11 picture
Na de uraim !
Mielőtt Kalex olvassa , térjünk vissza
a jó magyar illemhez és a tanya modorához!
Szép napot mindenkinek !
Padra Sándor
Alias :sasa11
Kari
Kari picture
Hello!
I translated it only_csak forditottam:
Jimmy LG gepe feher kepet ad minden bemenetröl_ugymint tv,scart,hdmi and vga_, hang van.
AZ IC100-ra gyanakszik, ujraforrasztasat tervezi_ van valakinek ötlete-tapasztalata?
Köszöni, Kari
zoltan35
zoltan35 picture
Szia(sztok)!
Én azért a forrasztás előtt/mellett megnézném a tápot... és mainboard C1141, C1152, C1163, C1193, kondikat (100mf)
Nekem 3-4 alkalommal ezek okozták az ilyen hibát.
Hm, mire az én angol (akár héber) tudásommal ezt leírnám, elporladna a készülék... :help:
Üdvözlettel: Kiss Z.
Kari
Kari picture
Hi Jimmy20!
Zoltan told:
Before you will decide to resolder some components, you`d check the mainboard supplies, espetially C1141, C1152, C1163, C1193; they (100uFs)are usually to change! He was 3-4 times succesful on these way...
Regards, Kiss Z.
kari
zoltan35
zoltan35 picture
Szia Kari!
:bow: :happy: Köszönöm!
Üdv, Z.
