replaced the drive belt, fixed the eject door and glued the record switch. but now the play switch does nothing, fast forward and reverse work as long as the switch is pushed in. When turned on the lights come on and the drive motor is turning but put in a tape and press play and nothing. Has anyone else had this problem? Thank you, any help would be appreciated.
