Onkyo CR-265 CD drive won't close electronically nor stay closed manually.
Greetings
Onkyo CR-265  CD mechanism malfunction.  While replacing CD yesterday, the CD tray did not react to the CD close/load button.  Closed it manually, and it popped back out after a few seconds.  I have the unit open and nothing is obviously broken.  I replaced the small belt but no change in symptom.  Drive insists on keeping the tray open.  Seems like the driven gear spins in one direction only.  Electronic or physical problem?  Many thanks for any suggestions!
Shizo
Shizo picture
Hi!
"...CD tray did not react to the CD close/load button. ".
Measure button resistance when pressed, if its more than 100 ohm then Open/Close not  detected.
