Falla mi equipo
panasonic SA-AKX600
devo recalacar que la falla se origino por caida de tension en la linea de 220 y se me apago mi equipo
por los cuales revise la parte de la fuente conmutada que esta bien pero al conectarlo de nuevo apreto encender solo el cooler no mas prende lo demas nada y al tenerlo apretado el sube el voltaje de la fuente pero no enciende nadade antemano gracias porsu ayuda
Failure of my panasonic SA-AKX600 sound equipment due to the 220 volt power supply that did not arrive and it turned off and the fault would start.
I must recall that the fault originated from a voltage drop on the 220 line and my equipment turned off
For which I check the part of the switched source that is fine but when I connect it again I press only the cooler to turn on, nothing else turns on and when it is pressed, the voltage of the source rises but it does not turn on anything in advance, thank you for your help
