Hi every body,
could you please help me, i have a panasonic Hifi amplifier sa-xr70 but it doesn't turn on.when i push the power buton the led get off for 3 seconds then turn on again.the display is always off.
thank you very much
2025, April 20 - 21:36
#1
Hi every body
after hours of tests and reparation ,the xr70 turn on now, but i am geting "F70 hdmi" error.
could any one help me please.
Hello
Try factory reset with key combination.
Hi Shizo,
thank you very much for your help. but how can i do factory reset, i don't have the manual
hello:
https://elektrotanya.com/showresult?what=SA-XR70&kategoria=&kat2=all
thank you very much SzBalint for helping me to get manual.
i have tried to do a reset but i get always the same error message "F70 hdmi" and then message to turn off the ampliier .on the manual they said that when we get the "F70" message we should turn off and contact the society panasonic.
could any body help please.
hello:
https://www.youtube.com/watch?v=V-Go1UmJHL4
F70 HDMI. Check HDMI connection. Turn off the system then turn it on again. Disconnect and reconnect the HDMI cable.
https://elektrotanya.com/content/panasonic-sa-he70-sa-he90-f70-hibakod
Hi SzBalint,
thank you very much for your help, it's very kind of you.
i am not using hdmi cable, i want just use the tuner fm, but i get this hdmi error. at the begining the machine didn't turn on at all, i found that the probleme was with the"volt detect" signal , i gave a 3volt dc at the pin 6 of connector cn605 wich is the volt-det and the machine turn on when i press power buton, every thing seems to be good ,the tuner fm is shaw on the display , but 3 seconds later the message error "F70 HDMI" appear on the display.
if any body have an idee about this probleme?
hello:
panasonic error codes
https://elektrotanya.com/panasonic_error_codes_for_audio_products.pdf/do...
