FIGYELEM! Olvasd el az alábbiakat!
Ezek az információk csak szakemberek számára hasznosak!
Súlyos és maradandó károsodást lehet tenni a készülékekben, ha nem vagy jártas azok beállításában, javításában. A belépés GARANCIAVESZTÉSSEL jár!
A szerviz menü csak egy lehetőség bizonyos működési paraméterek beállítására/hangolására, az elromlott készüléket nem lehet ezen keresztül megjavítani!!
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
Hold down the {VOL -} button ON THE PLASMA TV.
Press the {RECALL} button 3 times on the remote.
The Service Menu will be displayed.
Use {1} {2} on remote to navigate main menu items.
Use {3} {4} on remote to navigate sub-menu items.
Use {VOL+} {VOL -} on remote to change item value.
Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
Power off to exit service mode and save.
PA25UP / PD25UP / PX25UP :
Using the remote control:
Press the {MENU} button.
Set "Antenna A" to "Cable".
Select "Timer" menu and set sleep timer to 30 min.
Press {OK} twice to exit menus.
Tune to channel 124.
Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
Red "CHK" for Serviceman, Yellow "CHK" for Aging
Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu.
PA20UP / PX20UP :
Press "Setup" menu.
On "Mode" menu, select "Cable"
Press {ACTION} twice to exit menus.
While the "CHK" is displayed, press the {ACTION} and {VOL+} buttons
Red "CHK" for Serviceman Yellow "CHK" for Aging
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
LCDs / CRTs / RPTVs :
Hold down the {VOL -} button ON THE TV.
PROJECTORS :
Go to "Options" menu.
Highlight "OSD".
Then press and hold the {ENTER} button,
until the Service Menu is displayed.
Press the {MENU} button to exit.
PROJECTORS:
Turn the Projector on.
Press the {POWER} button.
A "Power Off" confirmation will come up on screen.
Then press {LEFT} {UP} {DOWN} {UP} {DOWN} & {ENTER} buttons.
To exit, turn the Projector Off.
PLASMAS 8UK / 9UK:
Hold down the {VOL -} button ON THE PLASMA DISPLAY.
Press the {STATUS} button 3 times on the remote.
(Status button is the one above Setup button)
The Service Menu (CAT) will be displayed.
(CAT = Computer Aided Test Menu)
Use the cursors keys on the remote to select a mode.
And press the Action key {} to access the menu.
To exit each mode, press the {R} button.
To exit the CAT menu, press the {STATUS} button.
Press {POWER} button on the Plasma to exit the service mode.
PLASMAS 3UY / 4UY / 5UY / 6UY / 7UY:
(Status button is the one below Power button)
tx29ps12
ALIGNMENT SETTINGS
(The figures below are nominal and used for representative purposes only.)
To access Service Mode select program position 99 and set sharpness to minimum.
Press “MUTE” button on remote control and at the same time press the „ˇ” button on the customer controls at the
front of the TV, this will place the TV set into Service Mode.
Press ˇ/^buttons to step up / down through the functions.
Press + / - buttons to alter the function values.
To exit Service Mode press „MENU” button.
Csak óvatosan!!
