I'm trying to figure out what is causing green tint on this monitor it is only visible in input and in only shades of grey, every think else looks good even blacks. Any ideas?
The emission of the CRT cathodes decreases, the white balance changes. It must be adjusted on the RGB output stage and the G2 voltage.
These are already retired.
I fixed that, found service manual, found service menu and adjusted green bias.
Hello,
Hello!
Did You try to use your monitor with different video sources, or cables?
Tom
