Completely dead. No functions or display. +12 volt supply is down to 10.8v: 5volts supply is ok (5.3 volts).:3.3 volts is ok: -12volts is is 11.3v: -24v is 22.8v have checked all diodes and related electrolytic capacitors.
(1)download philip 3005 service manual.
(2)see p.5 signal flow. panel ON only when MT1389C is OK and +12V -24V power K CLK & DATA are OK as well. p.11 E/F 3/4 area.
(3)check MT1389C pin105 reset signal with an analog 40~50MHz oscilloscope with slowest time base and 1v/div.
(4)check crystal 27 MHz at A1 area with probe x10 at C39 and C40 to see sine waveform at 27Mhz here.
(5)if 1-4 OK,see if data & clk signal for panel are present at pin92~95.
(6)1~5 ok but cannot turn on still. Check flash rom p.12 reset, vcc, data (D0-D15)and adress (A0-A20) signals.
(7)Right voltages will not make this stuff turn on if MT1389C & flash rom are dead. Failure chance of flash rom is very low indeed. The chance of failure of MT1389C is half half.
Is the red LED (standby) lit?
No the (standby) red led is not lit. No display at all
Check CN301 pin1 power voltage
Check all buttons opened
PHILIPS DVP3005 Service Manual download, schematics, eeprom, repair info for electronics experts
