Hi,
Usually, the power supply and the processor of the touch screen control panel work together. At a branded service center, the machine's software can be updated in a matter of seconds using the appropriate interface. It may happen that the machine does not work properly only after replacing the power supply panel because it does not recognize the information from the control panel software.
Best regards
Thanks for the answer.
I have had totally dead PCB but flashed it with firmware from similar model (but not the same).
It started to work, and all features worked apart from hot water. So I am looking for original firmware from SM5573/10R1. It can be downloaded via SWD interface of micro-controller. It's not encrypted and also processor is not locked.
Hi,
Best regards
