Dear
Greetings fromVU2.
I am trying to change mic from Icom to Motorola PTT Mic with out DTMF. I need only PTT for my ICOM IC2200H
My PTT mic is no functional. I bought new a switch (not original) and replaced it. It worked for a while and failed. Spares are hard to get in vu land. So I got one used Motorola Mic with PTT switch. No DTMF. I need o to work with PTT only..
Please help me to pin point info to rewire the RJ 45 in Motorola.
Regards
73s
Ratna
VU2LT I am QRV on HF 40 meters and occasionally 20 meters.
Hi Ratna,
you can check at mods.dk too. Maybe there have some idea or the needed documentation in forum or even between files...
You have to register only.
Hello!
If I were you, I would try to repair the original Icom microphone. I am attaching the Service Manual, the PTT button is a simple SMD microswitch, it is not a big deal to repair. I would need a model number for the Motorola microphone, based on that you can find a pinout, but in my opinion this would be the final solution.
Regards: Tony
http://www.radiomanual.info/schemi/ICOM_ACC/Icom_HM-133_V_serv.pdf
