Please help to find the part for Philips TV Power PCB
Please help to determine the part name for the special kind of diode used on the Philips Power PCB: p/n 2300KEG033A-F, Rev 3.5 (The PCB used in LCD TV: Philips 47PFL3603D/F)
csoxi
Hi!
Please enter the part number of the part!
Best regards,
Vote up!
You voted ‘up’
Oleg139
Hi,
It is D101A.
Please help to identify the component for Philips 47” TV.
This component is probably a TVS diode with Zener located on the Power Board named 47” IPB MR 3.1
The board p/n: 2300KEG033A-F, Rev 3.5
The component has a reference designator is D101A
Vote up!
You voted ‘up’
tomirevesz
tomirevesz's picture
Welcome!
If power supply number PLHL-T722A then D101=1N4007
https://elektrotanya.com/philips_2300keg031a-f_plhlt721a_272217100569_sc...
Vote up!
You voted ‘up’
Oleg139
  I am sorry my PCB 2300KEG033A-F Rev 3.5 the Reference Designator is D 106A (not D 101A) ! ! !
Vote up!
You voted ‘up’
Oleg139
Hi,
Unfortunately, it is a different component. There are several power boards for this TV.
My one is not 2300KEG031, but 2300KEG033A-F Rev. 3,5 It uses different IC for the converter and It is not Just a diode but TVS (having combination of the diode and Zener). The part Ref. Des. not D0101 but D101A
Please Help
Vote up!
You voted ‘up’
tomirevesz
Vote up!
You voted ‘up’
Oleg139
This schematic is not 2300KEG033A-F Rev. 3.5 and it has different reference designators for components.
My one has the DC-DC converter with designations 1xx, not 9xx. It use different IC -  U101 (FSQ510M), which has internal FET, and has single TVS component (diode and high voltage Zener in the single housing) gesignated as D106A.
It is possible to read on this TVS something like  T2D83. However, I could not find it in any catalogues.
When D106A fails it cause the IC U101 and fuse F101 fail as well. I need to recognize the model of D106A to fix my TV
Please Help
Vote up!
You voted ‘up’
tomirevesz
Vote up!
You voted ‘up’
More similar content
