ADMINISTRATOR: Please move this to the appropriate forum. The forum titles are in Magyar and I cannot understand them.
The Samsung CLP-310/315 and CLX-3175/3178 are great color laser printers and can be had quite inexpensively. But a set of replacement cartridges can cost more than the printer.
Refill toner is very inexpensive--I use Meritline.com but there are other sources--but the cartridges contain an I2C EEPROM which records page count. You can refill the cartridge but it will still be reported as exhausted.
A quirk of the printer design is that the original cartridges that come with the printer have no EEPROMS; their counts are stored in system EEPROM. With a simple modification to the printer you can erase these counts and cause the printer to accept any cartridges for multiple reuses.
This is documented at http://rumburg.org/printerhack/ . I've done this to two printers and it has worked well for me.
Larry M
Szia (Hi)!
Dear Larry!
Translation recommend Google translator. Link
Accordingly: Printer= nyomtató Link
Üdv (greeting)! Kalex
moderator
Hi Larry,
You reset solution good work but users advanced level of electronics knowledge.
Can be purchased Ebay any printer chip reset using basic knowledge and printer not injured.
Best regards,
