Helló,
Keresek egy áramköri tervet (áramköri rajz) a Samsung TV -hez. Samsung UE50NU7099U Alaplap BN96-46823a Már kipróbáltam a különböző keresési funkciókat. De nem Az áramköri rajz megtalálható. Még eladásra sem. Kérem, segítsen. Hiba: Lásd a Fotókat
Led sor ("élvilágítós", 2db csík) hiba. https://www.ebay.com/itm/203029431588?_trkparms=amclksrc%3DITM%26aid%3D1...
Üdv, Z.
Köszönöm a gyors információkat.
Hogyan nem találhatom meg az áramköri rajzot ???
Service Manual???
Hi eddy2023,
Your tv backlight strip is fault. You have to buy new set.
https://pt.aliexpress.com/item/1005004713609053.html?gatewayAdapt=glo2bra
Hello again, thank you for your help.. my second question is now.. I still have a defective television. And I can't find a service manual. Manufacturers no longer sell circuit diagrams????
What is the exact type of television?
1x Samsung UE50NU7099U
1x samsung UE55F7090SL
samsung UE55F7090SL
Mistake. When you turn it on, the tv comes on and then turns off again. The background lighting comes on briefly. Power supply: BN 44-00633B
Hi,
You will try disconnect maionbord power supply cable, and plug AC power to power supply board.
Backlight works?
Hello,
yes also have mainboard completely disconnected. Error is the same... Power supply turns on and after a second turns off. and so it repeats. on,off,on,off.
Backlight also goes on off on off.
I think either something is wrong with the power board. but I have not discovered anything. have re-soldered everything.
think the protection circuit jumps in. that's why it goes off immediately. then on again.
but I can't find a circuit diagram.
Have made video. Here is the link.
https://www.dropbox.com/scl/fi/kx4ezrtm4520utx2ibs9s/video_2023-10-08_21...
Thanks for the help.
Hi eddy2023,
I think your tvs backlight strip are fault.
You will have to check backlight strips.
If you disconnect backlight strip to tv works good, You see picture by flashlight?
I disconnected the LED strips and plugged them into the lab power supply. Tested with lab power supply. All LEDS were equally bright...
Did you break the display? Because one of the LEDs may be short-circuited, which is not visible on the display, but the electronics will prohibit it. Measure the voltage on each segment, at constant current, it should be the same.
Hi,
What is wrong with which type?
