Sony KLV-32V550A TV have picture solorization issue. I changed the TCON board but the problem persists.
Suspecting issue with Main Board, Please help which specific area and components on Main board i should check for troubleshooting.
Thanks
Check voltage at lvds cable conector (.8 v-2.5v) there s a data coupling coil from processor to this lvds conector
that coil may be open also check for rust in display connector.
Also try for reflashing the software with corect panel resolution
Hello
Replace the AS15F on t-con board.
