Sony tuner LBT-D505 not working, display is very dim
Hi, it's about the LBT-D505 Sony tuner. The display is very very dim when pressing the [On/Standby] button. I hear the power relay switch on. If I measure the LA5667 voltage regulator on the Power Board on pin 5 it produces 5.6V as noted in the schematics. However if I switch on the tuner by pressing the [On/Standby] button the voltage drops down to 0.8V and the display shows FM 87.50 and stays on. Pressing the [On/Standby] button again then the display shows "OFF" and after a few seconds the power relay is switched off and the voltage on pin 5 returns to 5.6V. If I disconnect the 5.6V pin 5 and connect an external power supply at 5.6V to the circuitry then when pressing the [On/Standby] button the power relay switches on but after a few seconds it switches off. The current drawn in Standby mode is then 15mA and when switched ON it is 22mA. I think anyway that the power regulator chip LA5667 is defective because some circuitry on the tuner PCB has ruined it. What could be the cause of this?
torokj
torokj picture
Hi,
I would replace the electrolytic capacitors in the power supply. C804,806,807,808,812,813.
Is the VFD -29 Volt OK?
SzBálint
SzBálint picture
